Message |
inconel intake valves I requested without charging anything extra, but that was a far cry from the actual cost of fixing that problem. It wiped out both intake cams and bent several valves. It destroyed the solid lifters on the intake valves too and damaged one of the heads.
[ ashspecz.com ] [ agpowers@bellsouth.net ] Enthusiasts soon understand each other. --W. Irving. Are you an enthusiast? If you are out to describe the truth, leave elegance to the tailor. Albert Einstein
